TwinTurbo.NET: Nissan 300ZX forum - You need to gap the plugs down to prevent misfire.
Subject You need to gap the plugs down to prevent misfire.
Posted by Ash's Z on July 15, 2006 at 12:28 PM
  This message has been viewed 327 times.
In Reply To When going up in stages do you need to re-gap your plugs? posted by BeegsTT on July 15, 2006 at 12:22 PM
Message Higher boost = more air in the cylinder. Air is resistive, so the more air you have, the harder it is for the spark to jump the gap. A large gap is harder to jump than a smaller one. Factory plug gap is 0.044" and this needs to be dropped down to 0.035". It isn't done for reasons of detonation, however, it would be advised to switch to the 6B plugs (as bernie noted) as they are a cooler plug and this will prevent pre-ignition (which is different than detonation or misfire).
Also, be sure to go through the 6 P's before you start turning up the boost. All of this is documented in that FAQ as well as several other items you should test.
[ http://twinturbo.net/net/viewmsg.aspx?forum=technical&msg_id=922678 ]
Good luck to you!
[ ashspecz.com ]
[ agpowers@bellsouth.net ]
Enthusiasts soon understand each other. --W. Irving.
Are you an enthusiast?
If you are out to describe the truth, leave elegance to the tailor.
Albert Einstein
